My surf is a 1993 SSRX 3l diesel with the estate body.
In the main passenger area the copurtesy light is also a fancy big air filter - it has a wrap-around clear light cover under which are 4 (2 each side) small capless bulbs. The only marking to give away the bulb rating is 3A - but of course bulbs here are rated by Watts.....
Can anyone tell me what they are please??
Next - in the boot area, the small courtesy light above that, immediately inside the tail gate - that bulb is missing - so I've no idea what rating it is - the fitting looks like it must be a very small flourescent tube style of light - maybe just over one inch long?
Again, can anyone tell me what type/rating bulb that should be please??
I thank you!!!
I thank you!!!
