where to start????
KerrSurf and I spent a good few hours yesterday trying to sort a knackered rear fog lamp.
Replaced the old lamp with a new one, connected up, nadda....
different bulb - nadda
located the switch, the warning light, the wiring, removed the warning light from the circuit in case that was the problem - nope.
No power at the switch. hmmmm.
Found a cable that wasn't connected to anything, not part of the original loom, that did have 12v when tested from cable to earth.
Tested switch with continuity tester - working.
connected switch to the powered cable, and tested switch to earth - 12v when switch closed, 0v when switch open.
Now, bring lamp into the front (to prove it's a break in the cable from the switch to the rear of the truck) - so power to switch, switch to lamp, lamp to earth.. - NOTHING!!
Continuity tests on bulb and lamp housing connectors all good.
WHAT THE HELL IS GOING ON????
Next thing is to buy a full fog lamp kit - switch and all - and fit that from scratch, using the instructions from that to see what stupid mistake we've been making....!
