rear interior  boot switch where is it? Light comes on if you use switch on roof, but wont work when open tailgate.
rear interior light
Yes it is switched from the rear lock sensors (Switches). I suspect that you would have problems with the rear window if the sensors are dodgy so I woulld check the switch in the light itself.
Rich.
This may help
.Originally posted by anthony whatfordrear interior boot switch where is it? Light comes on if you use switch on roof, but wont work when open tailgate.
It's probably the switch position on the light has a bit of dirt under it. Switch the switch back and forward a few times. It was like that on mine.
Had the same problem. Played with a meter for a while and figured out it was the switch in the lock. The lock on mine couldn't be dismantled unfortunately but a very heavy dose of WD-40 and opening and closing of the door made it work. I only had one lock to worry about tho (3rd gen).Originally posted by anthony whatfordrear interior boot switch where is it? Light comes on if you use switch on roof, but wont work when open tailgate.
Similar fault
Hi
I have had a similar fault, my switch stays on so with the light in the door position I ran the batteries flat while working away. Cost me an RAC life to get back on the road and £140 to replace the batteries before I found the light was staying on when it got dark!
Mike
