Alternator Wiring
  • Alternator Wiring
    Hi All,
    My alternator stopped charging, so i fitted a sec hand one and it was charging ok but no ign lite, after 2wks this one stopped charging, i've had a new regulater fitted to the first alternator but if i fit it, that will blow again, i'm thinking about wiring it independently. This is where i need some help. i have a 3 wire socket from the alternator, white, Red, Blue-yellow.
    Have I Got This right.
    WHITE= sensor wire to BATT
    RED===Ignition feed (Ign switch)
    Bl.Yellow=Warning lite.
    Any help on this will be much appreiciated
    drpete
    Originally posted by drpete View Post
    Hi All,
    How do you know the new regulator will blow?
      Hi Albannach,
      Having 2 alternators blow on me, makes me think theres a problem with the wiring, and the wiring is a mess under the bonett. I am going to try and check the charging wiring system tomorrow, but i think a independent rewire will be easier.
      Regards
      drpete
        If, (and that is only an if, as you could have suffered from bad luck alone), there is a wiring fault, you should sort the fault. The alternator and batteries aren't the only things connected to the charging circuit.
