Central Locking? or Single Locking...
  • Central Locking? or Single Locking...
    Hi Guys,
    Does anyone knows how to locate the central locking unit in this model? 1996 SSRG surf, 5VZ-FE... all doors lock from the drivers door panel, but they will not lock if i use the key. any cable i should look for?
    thanks,
    Vladimir.
    Great site!
    have a look under the drivers seat mate,
    SWIFT AND BOLD
      Check the wires in the drivers door loom for continuity too.
        Hi MattF,
        thanks for the reply, do you have any idea what colour cable i must look for?
        thanks...
        ____________________________
        Vladimir.
          Nope. Check them all anyhow. If one has been worn through, there will most likely be more, so you should check them all regardless.
