Hi
Have a import Hilux SSR G TD Automatic which for the last year or so has a battery drain which means that after 10 hours the car won't start. I've tried replacing both batteries. The alternator is fine and charges both batteries correctly. However once switched off I'm losing charge and then both batteries are sitting below the required voltage.
Have currently got a mechanic looking at it and have sent him some wiring diagrams. Has anybody come across a similar problem or can advice where to logically start . He's hasn't found the drain over a few days.
  slowly but surely building a strong good truck....
