I've just bought a Surf 1993 K reg have had new head fitted, however, Heater plugs don't work , no light showing in dash any ideas
Newbie
When the ignition is on, is the dash mounted digital clock working, on mine a fuse went that took out the clock and something else that is part of the glow plug heater system (it was located in the driver footwell RHS). Also check the massive glow plug fuse under the bonnet.
also as you are about to start (preheat) watch the dash, a little yellow coil symbol lights up for a fraction of a sec (glow plug symbol)...then listen for a loud click, then start.Last edited by Vultch; 27 June 2009, 14:39.__________________
Back in the day Baby
Heater Plugs
Sorry . didn't introduce myself , just bought Surf, never driven one before , only bought i because, I tow a caravan and mpg is not really important as most days i do about 20 miles per day. Any way thanks for sugestions , she doesnt start well at all takes about 4/5 attempts and chucks Black smoke everywhere.Originally posted by adrianash View PostI've just bought a Surf 1993 K reg have had new head fitted, however, Heater plugs don't work , no light showing in dash any ideasA J Ashcroft
on mine the glow plug light, (little coil spring) on the left of the dash lights only for an instant as I turn the key to on, it then takes 15 seconds to "click", then its turn the key all the way and vroom vroom, away you go. If I try to start without the pre-heat its similar to yours but no black smoke just a single puff of bluish. H
Def no pre heat then ...get it repaired as soon as you can, the starter motor does not like being used that hard, well mine did'nt....Originally posted by adrianash View PostSorry . didn't introduce myself , just bought Surf, never driven one before , only bought i because, I tow a caravan and mpg is not really important as most days i do about 20 miles per day. Any way thanks for sugestions , she doesnt start well at all takes about 4/5 attempts and chucks Black smoke everywhere.__________________
Heater Plugs
ThanksOriginally posted by Vultch View PostDef no pre heat then ...get it repaired as soon as you can, the starter motor does not like being used that hard, well mine did'nt....
Do you think ts heater plugs or could it be electrica, when I turn on ignition no light on dash for glo plugs any suggestions
ThanksA J Ashcroft
