Many thanks for responding, the guy i bought the surf from in April told me that the mirror never worked. I did try the WD40 trick but no change so i started checking the wires from the switch, i was able to work out what most of the wires do apart from the solid green wire which had no voltage or earth on it. when i press the switch open or closed i can here the relays energizing, that is why i was after an EWD to get an idea what the green wire does. I guess i will probably have to take the mirror apart and check from there. If you do come across an EWD or any other clues please give me a shout.
Many thanks for the info, i have already downloaded the files and guess what? they cover most area's apart from the power rear mirror. the files all relate to the American 4 runner which all have petrol engines, although useful i was hoping one of the forum members might have had a diesel version and it would have covered the mirror.
Thanks again for taking the effort to post a reply.
Success at last! I have cured the power mirror. i removed the rear spoiler section and motor/relay assembly. I had worked out what the six wires where and supplied power and earth to both the relay and motor and hey presto the mirror operated. Rebuilt the assembly and plugged it back into the main harness and tried the switch and it worked fine. I never found anything that was not correct, i can only guess that perhaps it was one of the wire connectors that i had removed and refitted. Anyway i am really pleased as it had bugged me from when i first bought the Surf that the mirror didn't work.
