Hi folks - here is my cry for help...
I'm no electrician, so I am struggling to work out what is going on in my surf (KZN130). I have had an intermittent problem with the windows and today its gone Pete Tong....
1) Rear door windows - will not operate from their own switches. Window lock is not on. Left rear window will go down (but not up - help!!) using drivers panel switch. Right rear window will not work at all form any switch.
2) Also rear tail window now not dropping - no switch noise. Only the "UP" bit of the UP/DOWN console button lit when lights are on (used to be both sides of switch illuminated). Rear wiper working normally. Rear door/window will not work with the key at all either.
3) Rear heater element not working - but other posts indicate disconnected or loose wires - so not worried about that right now!
Currently have nearside rear window open, with no way to get it back up!
Anyone with any ideas? Just glad its not raining! I have checked and replaced all fuses (by accelerator pedal). Front windows all work normally, as does central locking.
Are vehicle eletricians worth the money? I love my surf, but pennies are short. Any advice from you greatfully received. I can just about work a voltmeter bu that the limit of my understanding.
Thanks in advance,
Locky
Thanks in advance,
Locky
 good luck
. I expect its a broken earth between the drivers door panel and the window (most likely at the a-frame) but doubt I can fix myself. Will look at the guides on here before i part with my cash though...
