hi everyone got aproblem mirrors not working got power at the switch anybody got any ideas thanks
electric mirrors
Same problem here mirrors stopped working after I had the dash out and replaced the aerial which was knackered when I bought it. Decided to try and tackle it today and took the door panel off. All wiring seems to be intact in the door, went to reassemble and now the door light won't work and I think the central locking has now stopped from the switch! (the door switch operates all t the other doors but not the driver's door although to be honest I don't know if it did before???!!)
All in all not very productive - mirrors still don't work and now the door light doesn't work. Any Surf Ninja's able to offer some wisdom before I go mad?!
Cheers,
Tom.
Having had it apart again there is no power going to the mirrors or drivers door light but there is to the windows. As I can't find where the power stops could I tap in to the window power wire (black&white?) and run power from that to the mirrors and the door light?
Cheers,
T.
