Interior lights and sound system
  • Interior lights and sound system
    Just bought a 93 surf, all the electrics work fine except for all the interior lights and the cig lighter. At the moment there is no stereo fitted, is this all on the same loop?
    Thanks for any assistance.
    Tim
    You have a fuse box in the drivers footwell near accelerator pedle. check the fuses there
      Checked the ciggy one OK, will check the others later thanks.
        I had the same problem after a stereo was fitted, when the dash was put back together the cigarette lighter was not plugged back in from the rear of the dash.
        this is worth checking, took the dash out of mine and plugged it back in. All is ok now.
        1993 SSR-G 3.0TD KZN130
