Yesterday went out to start the car and both batteries were totally flat!! Tried a jump start with no luck. So replace both batteries and started no problems. But now my rear window will not go up or down with the key or the dash switch. Before the flat batteries the window went up and down perfectly. I can still hear the relay click in the back. Anyone have any ideas???
Battery / Rear Window Problems
Just checked all the fuses! All ok. Tested power suply to the motor and it works fine! Tried direct power from the battery onto the motor and it didn't shift it! Looks like it a trip up to Dalcrue Autobreakers for a new motor. Lucky it only 5mins away!! What motor should i look for??? They have 4 or 5 Surfs up there so ill try them 1st!Work to Live NOT Live to Work!!!
