Electric Aerial
  • Electric Aerial
    I have a SSR-G 3rd Gen.. The electric aerial has starting making horrible noises. How do I gain access to it to check/replace it?
    I would grateful for any help.
    tarquinBB
    is it still working? chances are the plastic teeth on the end of the mast that goes into the motor are on the way out. You can buy a replaacement mast set up from roughtrax, really easy to fit took me about 5 mins. If you want to get to the motor its self remove the inner wing and its there. hope this helps.
    SWIFT AND BOLD
