I`ve fitted another alternator to my surf cos the ignition light wud not light up and was not charging, assumed it wud be the alternator but i`ve got the exact same prob after fittin another one. I`ve checked all fuses i can find and all are ok. When i put it back together the 1st time i had all my dash lights workin but as soon as i started it up the alt was not chargin and now i have now igniton light again. Any clues any1 pls thanks Don..
Any ideas? its doin my head in now
Hi mate its the alternator i had from u today lol. Batteries have enuf in them t start it tho. Also now its decided to light up all the dash lights all the time now no dif if its runnin or not. Do u reckon the batteries cud do that? Ive checked all earths etc and all seem ok.
Do you have a voltmeter or multi meter, if so put it across a battery and measure voltage, then rev the engine the voltage should creep up, if so the alternator is working...
e.g at idle 11.9 volts..rev engine 12.5 to 13 volts....__________________
Back in the day Baby
Yup done that had just under 12 at idle then crept up tp 13.6 ish with revs but that was when i had no ignitin lights, now i have ignition lights all the time even with the engine running i have no charge from alt. eg volt meter readin 11.98 when running. Ther must be a fault somewhere as i think having 2 dodgy alts is a bit slim
With engine off... but pull lead from alternator, one or more of the pins in this plug should have a voltagewith the ignition ON ...alternators need a voltage supplied to work..if no voltage present on any pin then it might be a fuse....
ALSO...I am not an expert on the Surf fuse layout..but in the drivers footwell right hand side of pedals there is a fuse box, pull off the plastic cover and check all the fuses, its arkward to get the fuses out..long nose pliars helpLast edited by Vultch; 31 December 2008, 18:25.__________________
Charge warning light works on potential difference to make the bulb go out . IE with ignition on and engine not running you will have positive 12v running through the dash light then through the alternator making an earth which illuminates the bulb . With the engine running 12v positive back up from the alternator to the dash bulb puts the bulb out . Then with ignition off the 12v positive supply is cut from the system and the bulb is out . 1st rule of testing alternator is to check that the bulb is illuminated when ignition is on . If that is OK then the fault lies within the alternator (in most cases) or regulator if an external one fitted. If you have no bulb illuminated with ignition on then there is a break in the circuit somewhere . Could be the feed to the bulb , the bulb it self , or the wiring to the alternator .
Even with the circuit for warning light not working you can get some charge from the alternator ( not often and not much ).
Hope that helps .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
