The big problem with leaving the batteries connected in parrallel is a situation I recently had. One of the batteries died and as a result it killed the other battery. The battery that had a collapesed cell was draining the good battery down to 5v overnight. Lead acid batteries don't like being drained like this and it died a couple of days latter.
Best advice I can give is to put a 700CCA N70Z sized battery, or better, in the position where the heavy starter motor wiring connects (air intake side of a 1KZ-TE) and have some means of isolating the two batteries and control the charging of the second one.
This also means that if the main starting battery does fail or go flat for some reason you have a perfectly good battery sitting there waiting to be used to start the beast.
