Lighting Problem
  • Lighting Problem
    Gent's, My headlights won't work unless I switch on the rear fog light (which does not illuminate). When I switch the fog light on I have full beam only. Do you have any ideas waht is causing this please? This has only happened since using the fog light at the weekend.
    Either a fuse has popped or the contacts on the stalk switch are dirty.
      sounds like a broken wire to me or a bad earth
        Thanks guys. I still have the problem.
        I only have 1 sidelight, full beam only and no rear fog light. Any more ideas please? I cannot see any faulty fuses could it be the relay? I hear this click when I flash the full beam.
          Here's the problem: .
          My 4 Crawler loom burnt out. Does anyone know where I can acquire one of these bits please?
