rear window Help
  • rear window Help
    Hy Guys just bought a 3.0ltr to replace the 2.4. The rear window work's ok from the key in the rear tailgate, but does not work on the switch on the center console
    The contacts inside the switch are probably dirty, (contact cleaner spray will sort it) or the window lock button is pressed on the driver's armrest.
      did you get your alternator alright?
        Cheers bushwhacker, feel like a idiot forgot about widow lock switch. it was on.
        yes stormforce recieved it on wed, fitted it yesturday, all is well.
