My heated rear window worked once when I first got the Surf and has stopped working. The switch lights up, but there is no power to the window. I checked the terminals were still attached and found there was no power to them. Is there a relay somewhere I can check? The wires on the window are a lot heavier than those on the switch so I expect there is a relay somewhere.
Heated rear window problem
Hi matey
checked mine the other day as it had 'stopped working'. When I checked I found the terminals nicely attached but the wires supplying the juice taped back because the supply wires had broken, as previously stated.
Turns out it couldn't have worked since I got it....DOH!Keep your friends close and a hammer closer
