over the past few weeks i have been veiwing lots of surfs,a few days ago i came across a runner, the switch in the cab that controls the rear window does not work but yet the key works fine from the back door,the guy there said that he has never had a runner or a surf where this switch does work... is this a common fault ...... could it just be a fauty relay or is there more to it..........
4runner
If he's NEVER had one that works he most sell some right naff motors. Also the wire to the switch can be quite short/tight (if its in the centre console) and if someone has tried to lift the switch it may have pulled the plug off.Originally posted by slimover the past few weeks i have been veiwing lots of surfs,a few days ago i came across a runner, the switch in the cab that controls the rear window does not work but yet the key works fine from the back door,the guy there said that he has never had a runner or a surf where this switch does work... is this a common fault ...... could it just be a fauty relay or is there more to it..........Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
