It still won't bl00dy start :(
  • It still won't bl00dy start :(
    After the fun at Run To The Sun, I have now changed the battery terminals. Went to start the engine and all I got was "click" the starter motor will not turn over. Glow plugs heat up, well the light comes on goes off followed by the beeping. Hoping I've just got a loose wire in the starter causing problems. But anyone else able to shed some light on the issue?
    Hold my beer and watch this
    Dodgy contacts in the starter motor?
      I agree. As said by so many others perform a search on starter motor/contacts and all will be revealed.
      http://www.hiluxsurf.co.uk/forums/sh...arter+contacts
      Trust your Hound.
        Cheers for help, will have a look through. Never done anything like this before so should be fun
          You have charged the batteries I hope?
            yeah they're pretty well charged up, but will check
              Mine was doing the same after a dunking at Avalanche. Turned out the contacts were fine but the starter solenoid plunger was jammed. Good clean and a bit of grease and all was fine.
              Roger
