rear door open warning light
  • rear door open warning light
    hi again,
    does anyone know which colour wire going into tailgate is the one for the warning light on dash??
    if you got the rear spare carrier then make sure that is closed properly
      all closed fine, the whole story is,
      my rear window only went up, not down from key, fine on switch in car.
      i looked underneath and repaired all broken wires, ( one green/white, one green/yellow and one yellow/black).
      now rear window works fine but this light comes on, also my rear interior light doesn't work when opening door.
      sounds like fun i know, but as everything is now working fine apart from the light i thought i would just disconnect it????
      i hope your still awake and that this makes sense.
      cheers
