Hi all!
The Integration Relay, where located. This solid state relay is located behind the Junction Block 1 on the driver kick panel. It is actually part of the Junction Block assembly that contains fuses, relays etc. One would have to remove the Junction Block and cable connectors to be able to come to it. Being a solid state component, one does not expect it to be problematic in the operation of power windows etc, unless there was some pin corrosion due to water or moisture or cable breakage.
JL
JL
