Good evening all, I have a problem with my central locking in that it unlocks fine. But if I try to lock it with key or interior button it will not lock, if I open and close the door at the same time it works intermittently. So obviously I have a broken wire here, and was wondering if anyone knew what colour codes the drivers door wires are so I can find the offending wire. Any help much appreciated. btw its a 1995 kzn 130 3.0 ssrx.
Central locking
Hello,
In my '94 4Runner those two wires are the ones that close and open the doors if you ground them.
(Click pic to enlarge)
Don't remember which is each one but it's easy to test. The module it's located on the DS on the LHD trucks, I suppose it will be in the opposite side on yours.
David'94 4Runner 3.0TD - SAS'ed on 35's
