As its a common problem and the relay is so expensive, is their not a work around ?
I've been investigating the problem since the weekend when my window stopped opening on the key.
I can work the motor off a spare battery, up and down, so its the relay Rear heater works, rear wiper too just can't open door.
Is there a way to circumvent the relay, a switch direct from ignition perhaps.
