Just a thought but when and if a resistor breaks down/blows or whatever they do which way do they go? let more volts through or cut off volts alltogether, (or either way)? thinking if i'm useing one resistor on lots of led in parallel and it goes it may blow all of em or just cut the power (which is ok, as it'll be easy to replace one resistor)
L.E.D. Resistors
Yeah, as mentioned, absolutely no worries about it shorting. If you used a highly over-rated resistor, (wattage wise), then the chances of it going high resistance or O/C are practically nonexistent unless you are really unlucky.
 Using a metal film rather than carbon is also preferable. Don't forget to pop a fuse inline either.
Cheer's mattOriginally posted by MattF View PostYeah, as mentioned, absolutely no worries about it shorting. If you used a highly over-rated resistor, (wattage wise), then the chances of it going high resistance or O/C are practically nonexistent unless you are really unlucky.
You are compensating|allowing for voltage drop in your design? Is the unequal brightness erratic in placement or otherwise? Are the L.E.D's from the same batch, i.e: all bought at the same time?Originally posted by SoundsDigital View PostI cannot explain why, but when I have connected a bank of LEDs to one common resistor, they never seem to give off equal amounts of light. Would 12 volt LEDs be more suitable?Last edited by MattF; 6 May 2008, 20:36.
It’s a bit of an unwritten rule but you should (if at all possible) never connect more that three led's in series with one resistorOriginally posted by SoundsDigital View PostI cannot explain why, but when I have connected a bank of LEDs to one common resistor, they never seem to give off equal amounts of light. Would 12 volt LEDs be more suitable?
If you check out most of the led resistor calculators on the internet, they generally only show calculations for the max of 3 led's. and should thus be installed in banks of 3Roy
When ya stop having fun, Ya start getting old
How many L.E.D's are you fitting? Generally, a single bank is fine. Only reason to make multiple clusters is as a failsafe, i.e: you retain most segments if one goes down, which, come to think of it, may be the preferable way to do it for a brake light. Make sure you get 1% tolerance resistors, however, to keep everything as close as possible.Originally posted by POPEYE View PostWhat about "in paralell" is it ok to wire as many as you like on one resistor ? and they will all be bought from the same place at the same time, or is it best to do em in banks as well
About 300-400 i hope, all depends on finding/making the encloseure for em, plus if i can i'm gonna build in a rude message in em, switchable of course,Originally posted by MattF View PostHow many L.E.D's are you fitting? Generally, a single bank is fine. Only reason to make multiple clusters is as a failsafe, i.e: you retain most segments if one goes down, which, come to think of it, may be the preferable way to do it for a brake light. Make sure you get 1% tolerance resistors, however, to keep everything as close as possible.
