Hello everyone, I am just wandering if anyone can tell me if there is a fuse for the rear window. Its not going down and I have just checked the motor and it's fine. I just can't find a fuse for it.
rear window for 3.0 litre
If you have checked the motor and its working then the fuse must be intact. Have you checked to make sure that the window lock switch has not been pressed?Originally posted by rossi1973 View PostHello everyone, I am just wandering if anyone can tell me if there is a fuse for the rear window. Its not going down and I have just checked the motor and it's fine. I just can't find a fuse for it.
SWIFT AND BOLD
Mine stuck a few weeks ago after being left for a fortnight undriven. I could hear the relay or motor trying to work, but would not move either by the key or rocker switch. Managed to push window downward whilst operating key. must have just seized with not being moved for a while - must lubricate side seals soon!!!Everyone thinks I'm paranoid!!
If the motor is running and the window won't go down you may need to have a look at motor to ensure the driveplate has not come adrift from motor.
do a thread search, plenty of info on here.Alan
