headlight
  • headlight
    if i have no offside dipped beam,but it works on main beam,and the fue id fine,is it just a bulb or something more sinister??
    Non intercooled nothing.
    Most likely your bulb
    Get ready for battery removal !
    Last edited by That Ruddy Squirrel; 10 March 2008, 21:10. Reason: brain fade - need nuts !
      thanks trev,halfrauds here we come !!
        Here's your instructions for bulb replacement
          DEEP JOY
          cheers trev,heres to a little frustration tomorrow
            DEEP JOY
            It's easy mate, remove the required battery (same side as the blown bulb) then undo the appropriate bottle (washer fluid or expansion and move it over in the space left by the battery, then you can get at the bulb.
            1/2 hour tops taking it easy.
              cheers trev
                It's not a bulb, it's a lamp. Bulbs get planted, lamps get fitted.
                  Filament lamp, to be totally pedantic.
                    Lamps get lit.
                      Lamps get lit.
                      The lamp/bulb bit is one of those swings and roundabouts debates. I ain't going there.
