I have a 1995 3.0 Td SSR-X, and I need to change my Electric Aerial.  Where is it easiest to access it? is it behind the panel at the rear of the left hand wheel arch, or do I have to go thru behind the Dashboard Facia on the Passengers side?
Electric Aerial
Panel in the wheel arch is how you get to the aerial.Originally posted by 9belo0 View PostI have a 1995 3.0 Td SSR-X, and I need to change my Electric Aerial. Where is it easiest to access it? is it behind the panel at the rear of the left hand wheel arch, or do I have to go thru behind the Dashboard Facia on the Passengers side?
						Paul </Slugsie>
Immortal.so far!
Aerial mast replaced!! easier than I first thought!! only had to undo the chrome Nut and remove the plastic Bodywork sealing cover, pull out broken mast and fed in new one. Thanks, anyway, for info on Aerial motor replacement.Better to be in Cumulonimbus than Cumulogranite
