Hi,anyone Know What Ohm's I Should Be Getting On The Front Speed Sensor? Mine Is Reading 13,and The Auto Elec Chap Recons Thats The Problem.cheers
Ohm's
Can I ask why you are trying to find the value? Also - what is it you are testing? Is it the speedo or something else?
13ohms is quite high and indicates that you have a good value - if you had super high resistance or non (0.02ohms etc) then you would have a short and that would give you a fault.
What is it you are trying to find?
There's some info here on the generic electrical side of things:
http://forums.bauchan.org/portal/vie...ds.php?dcid=14
