What this button do
Both my surfs have "automatic Cloaking Devices". I mean if you can't see 2.2 Tonnes of Red & chrome Toyota with loads of lights on then you really shouldn't be driving!Originally posted by BUSHWHACKERCloaking device switch?
Some Surfs have them, the ones that other drivers don't 'see' and pull out in front of at junctions.
My alarm panic button is in that hole BTWBring me the head of a treehugger
looks like a switch in my truck. It works the rear foglight, as does the switch near the rear window switch. So both have to be on before the foglight comes on. Think it originally controlled a set of front lights, which have long since been removed before I bought the truck. I will get round to disconnecting the switch and using it again to run front lightsHold my beer and watch this
Its definatly NOT the rear fogs,
it does however look like the button that turns on the TVs in the back so i assume its been added . . but it looks like its been installed properly like it was factory fitted but obviously doesn't match the style of the other buttons so my best guess it that someone had front fogs fitted, possibly done when they did the sterioIts all fun and games till someone looses an eye!
I have a switch where yours is to manually overide the electric fan switch.2.4 LN130 SSRG K Reg
Dropbox - You're invited to join Dropbox! - Online backup, file sync and sharing made easy.
To use Drop Box today for free click go here https://www.dropbox.com/referrals/NTczNzg1MzQ5
