Rear window control unit
  • Rear window control unit
    Hello,
    Just found this site and I must says I've learned alot in a very short time.
    Please would someone give me some advice with regards to the control unit for the rear window.
    My rear window seems to lower ok, but when I press the switch to raise it, somtimes it goes first time and then others I have to sit there for 10mins pressing the switch before the bl**dy thing moves.
    I can hear clicking coming from the control unit but no action.
    Does this mean the relays are faulty, if so can I replace them. Or do I need to buy a whole new unit and if I do from where?
    Thankyou for your help
    James
    Jameson
    1990 SURF 2.4TD
    Originally posted by Jameson
    Hello,
    James
    The answers are already on the forum, just use the search button, try this one from just a few days ago http://www.yotasurf.co.uk/Forums/sho...ht=rear+window
    Maurice
      Cheer's Maurice
      Jameson
      1990 SURF 2.4TD
        Have found relays for repair
        I have found (2) supplyers for relays to repair rear window control box e-mail and I will send info
        Tom
          Tom
          Tom, why not simply add the info on here ???
          Maurice
            relays
            Hi
            Try, www.invernesshiluxsurf@groups.msn.com
            I have poeted the info on this web page.
            Tom
              Hi Tom
              Cant seem to access that site, will send e-mail with my address if thats ok, so you can mail to me as suggested.
              Cheer's
              Jameson
              1990 SURF 2.4TD
                Web Page
                Hi try
                click on My storage Info in left hand side,then onto inverness hilux surf
                then click on pictures,and you will find all the info I have,let me know if it works.
                Tom
                  not working
                    Hi Morr
                    Im in my early 60+ and I am new to surfs, and I am just learning to use a computer "rinkleys take that bit longer to learn"
                    Tom
                      Hi Morr
                      Tom
                      No worries Tom, ya may be a wrinkley, but yere making a valuable contributiion keep up the good work.
                      Maurice
