Have replaced headlight bulbs in my 2nd gen, but aim is now too high. Bulbs are seated right. How do I adjust the beam?
Headlight beam aim
mark the centre to the lights on a surface like a garage door with a cross...reverse 2 meters...the centre of the beam should be on the cross for high beam and the pattern for low beam should be on/under the horizontal line and the upward sweep of the beam should turn up on the left of the vertical from the centre of the cross...
hope that makes sense...
Thanks, will give that a try.Originally posted by andyverran View Postmark the centre to the lights on a surface like a garage door with a cross...reverse 2 meters...the centre of the beam should be on the cross for high beam and the pattern for low beam should be on/under the horizontal line and the upward sweep of the beam should turn up on the left of the vertical from the centre of the cross...
