I have read a few other threads that are similar to my problem but fairly old so didn't reply to them. Is same from key or button operation.
My window goes down - no problems.
It only goes up when it feels like it.
I've pulled the control box from behind the nearside panelling and discovered:
- when trying to go down, there are two clicks - it is like one relay operates and causes second to operate.
-trying to go up, only one click
- if I tap the PCB (or the box when it is still boxed) - window goes up.
I tried to narrow down the possibilities by swapping all six relays (3 on left to right, 3 on right to left) and I have exactly the same problem.
I am technical, but cannot find a wiring diagram for this control board ANYWHERE.
Here in NZ, the replacement costs for Surfs are ridiculous (approx 1500 pounds for a radiator). One of these control boxes is 150 pounds - with no guarantee it will work.
Where can I find a wiring diagram for the PCB - I would be able to trace the problem if I knew where to trace.
Help a very stressed owner. Thanks.
