i know this has been asked before on here but i couldnt find it,the problem is the rear window was working fine now it wont go up or down fron the switch inside. it works fine from the key
thanks
mick
thanks
mick
Could be something as simple as a broken switch, although when my switch broke it would go up but not down. Or could be a break in the wire going from the switch, or worse. But I'd start by checking the switch.
