Can anyone help . My 80 amp glowplug fuse has blown and in trying to remove it I've managed to destroy it. How does the fuse come out of the fuse box ?
Glowplug Fuse
the 80a fuse is fixed from underneath so you will probably have to undo the complete fuse box just to get to the nutOriginally posted by murph4017Can anyone help . My 80 amp glowplug fuse has blown and in trying to remove it I've managed to destroy it. How does the fuse come out of the fuse box ?https://www.facebook.com/groups/henpals/
yep remove the fuse box bolts (2x10mm bolts) and then turn the whole fusebox upside down,then put a screwdriver in the plastic flap near the housing near the fuses ,both the 100 amp alt fuse and the 80 amp glo plug fuse will then pull down out of the fuse box.then you need an 8 mm spanner and 10 mm spanner to undo the bolts holding the fuse in.after the bolts are out you should then be able to remove and re fit new fuse!! it helps sometimes by removing the cable ties holding the wires to the bulkhead to give ya a little bit more room! good luckDONT RUN WIV BIG DOGS IF U CANT PI** UP TALL TREES
