Glow plugs
  • Glow plugs
    My glow plug indicator on my dash only stays lit for a second or two before I crank the engine.
    I very cold weather it stays on a fraction longer.
    Is it normal for the plugs to heat so quickly?
    The engine starts very quickly after allowing this quick heat.
    If I don't heat the plugs it takes a few cranks round to get going.
    I'm used to driving diesel plant that takes ages to preheat and I wondered how my Surf manages it so quickly.
    Alan
    The light will only be on for a second anyway.Listen out for the relay click before starting.Mine takes roughly 10secs till the relay clicks and then i start it up.The relay is on the n/s inner wing i think so you will have to listen carefully to hear it as it's rairly quiet
      cheers.
      Alan
        Originally posted by stormforce1067
        The light will only be on for a second anyway.Listen out for the relay click before starting.Mine takes roughly 10secs till the relay clicks and then i start it up.The relay is on the n/s inner wing i think so you will have to listen carefully to hear it as it's RAIRLY QUIET
        MIND OUT STORMY THE SPELLING GURUS WILL GET YA FOR THAT ONE
            I knew what he meant.
            Alan
