Folding Mirror - or not as the case may be!
  • Folding Mirror - or not as the case may be!
    Hi all, this is my 1st post as I only got my truck yesterday. I have folding mirrors but only 1 works. The motor operates, but no movement. However, it folds in and out by hand quite freely. Has anyone else had this problem? Thanks, Mike
    i would try to investigate it ty taking it apart if you can hear the motor spinning its probably a a drive that might of shifted or broke maybe when someone hit it i havent got them on my truck but it the rear window mechanism and sunroofs are anything to go by.
    Chris.
      Cheers for that Chris. I do belive taking it apart is the way forward. Now then, is this an easy task? Where do you start?
