right finally figured out how to remove the rear window motor woopee!!
then tested the motor found out motor is ok but the gearing is knackered on the bottom, since these two split apart is it possible just to buy the bottom housing with the gearing in, or do you have to buy the whole thing??
thxs for any replies
john
john
