i am adding to my previous post (dip/main relay at fault)
alternator, t-belt and filter light are still on !!
i have 13v on tickover and 16 v on fast idle and 14-16v with lights and heater on
replaced 1 of the batts
replaced voltage regulator (was thinking this may cure the lack of regulated volts) this is the external type.
ihave noticed that if i rev the arse off it, then the new regulator makes a buzzing noise and the dash lights nearly go out as the revs come down, but then they come back on.
ANY HELP FROM YOU GUYS? i am getting fedup with this now
