Im working on a California regd Surf. It has a 4cyl petrol engine, I dont know the correct designation but the truck is about 1990 vintage.
The truck wont start, there is no spark. Previous engineer fitted a new coil, to no avail. I diagnosed the sealed "electronics" pack bolted to the coil (mounted on the left front inner wing) is not receiving/emmiting correct voltages. There are 5 wires going in but only one shows 12 volts.
Does anyone have such info on the voltages or resistances? Or does anyone have such a coil/ignition set up that they could take some readings from and pass them to me?
Thanks in advance.
Thanks in advance.
