I know this has been mentioned many times before however i cant seem to make ends of a definitive answer. the wipers on my rear window stopped working and blew the fuses and other fuses i put in. the arm is not sat on the park position either so i think that stops the window from going down. any help would be appreciated.
rear window wiper
You can get the motor cover panel off from inside, it just pulls off, but go easy, the clips are brittle in this weather.
Then you can manually turn the motor arm to get the wiper parked properly. This will let you use the rear window.
The motor could be knackered, or something jamming the mech.
