where is ecu?, how do i remove the cover?
  • where is ecu?, how do i remove the cover?
    I'm being very specific here, i need to identify the ecu and know which mounting screws etc to remove to get the cover off. A pic or diagram would be very helpfull.
    regards
    Not specific enough to mention what truck it is.....
    On most trucks its behind the passenger kick panel, the lid is only 4 screws, its no trouble.
        hilux surf 3l td kzn185
        when you say kick panel, do you mean the panel at the left side, which has a box inside called 4wd controler
        or is it the big box straight down the footwell
        regards
          Not sure about the 3rd gen, the older trucks deffo by where the passenger left foot is, against the side of the truck. They normally say ECU or Emission control computer.
          But if you've been there it must be somewhere else, have you looked on the drivers side.
            internesting
            ill go and check drivers side panel
              Its buried in the dash behind the glove box by the looks of it...
                Just like the 1st gens!
                (oh and Rob..... no I'm not allowed your truck, but I do want the doors! )
                  absolutely BRILLIANT work
                  Ill explore this tomorrow
                  thanks a million
                    You want some door cards too????
                      Can the ecu be chipped????
                        yes to the door cards
                        thanks
                          Originally posted by iainanderson924
                          thanks
                          You don't want them, trust me
