Right i will try to keep this short but here is the problem. Normally ign on heater light on approx 2secs light off 2secs solenoid clicks turn key start. Now this has happened once before but sorted itself out? ign on no lights on dash apart from handbrake, heater light on 1 millisecond wait nothing seems to happen i can turn over engine but it is obvious heater plugs not working though it does start eventually. To be on the safe side i trickle charged the battery overnight ready for work in the morning just in case it needed extra winding over and turned the key and dash lights back on and heater plugs working? Get to work turn off ... same problem as before no dash lights ..heater plugs not working... but it does start? (1st gen 2.4/2l-t.. any ideas ?
