Passenger window
  • Passenger window
    The passenger window switch works on the passenger side door... but not from the drivers console... the funny thing is tho, when i press the passenger side switch and move the window either up or down then the driver side one works. but when i just go to use the drivers side switch the window doesnt do anything....
    any suggestions?
    thanks
    Conquering suburbia one speed hump at a time
    try taking out the switch from one of the rear doors and put in the passengers door to see if it works if so you need a new switch..
    its easy to do......
    CHEERS JOHN................
      Yeh sounds like a high resistance on the drivers door switch or wiring but as Slim says its easier to try the switch first.
      Laugh!!! I nearly bought my own beer.
      Paul
