About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/ts/bl-dtcs-10a.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.batauto.com/Toyota
http://www.anewtoronto.com/toyotacodes.htm
http://www.floathouse.com/ACE/Toyota.htm
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
If a fault is not stored then take voltage and resistancd measurements at each ECU pin and compare with the factory service manual that technique will pin point your problem as this is the technique that I use when troubleshooting tv's,vcr's,home/car audio equipment.
