Ok ive just done mine, it was slow and jerky and didnt go right up.
1. the motor was fine but the drive gear was very badly rusted and worn..a big groove in it.
2. The regulator mechanism was worn on the motor drive side to a point where the teeth were...points and 2 of the teeth were missing.
Solution, reconditioned motor from PaulyP off ebay and a new regulator from toyota and lots of grease on moving parts.
The runners at the bottom of the window were fine and the side guides ok also. I now have 23 razor sharp cuts mainly on right hand and rear window works perfectly. I raised window half way to remove all parts and re-fit (with the tailgate down ofc)
3.5 hours, i had to clean old grease away to remove parts and sort out motor connections
