problem dashboard light
  • problem dashboard light
    I have British built 4runner 3.0 TD and there is a small light on the rev counter which is premanetly on. The light used to come on for a couple of minutes every so often, but today it stayed. The symbol under the light looks like a fan wheel with 2 curved lines which look like flow lines, around the outside. Please could some let me know the problem or the cause of the problem so I can sort it out tomorrow.
    is it the check light for the coolant
      Is it any of these....
        At a wild guess... considering its on the rev counter.. could it be a turbo light..
        __________________
        Back in the day Baby
          From what I read of the problem "The symbol under the light looks like a fan wheel with 2 curved lines which look like flow lines, around the outside" are we not talking of the Brake warning light ?
          If so you have a problem with 1, 2 or all 3 of the following:
          1) Brake Fluid
          2) Brake Pads
          3) Brake Disks
          Trev
          ps as far as I am aware there is NO turbo light on a 3 litre
            I have included a picture of the problem warning light. I have tried all the suggestions a aprt from the brakes which I am having checked tomorrow
              It looks like an impeller or turbine, so to me that means turbo.
                HAS to be turbo. NO WAY its brakes. It looks like a turbo therefore it is TURBO
                Bogus
                Сви можемо
