Hi Guys
Was out yesterday got a bit hot so thought I would try my Air Con for the first time....
I have power to the button as it lights up.. but it made pretty much no difference to the temp of the air....
The surfs still in its 3 month warranty period....is this something I might be able to sort myself or something I should take back....
I had the air con on... air set to come from outside and the temp slide on cold with the fan on... I presume thats correct to get the air con working.....??
I had a problem like this with my last car which when I tried to get fixed got told the gas it used was now illegal and i needed a new air con unit!! Does the older surf '93 use that old type of gas does anyone know? or will it most likely be just a case of needing re gassing?
