Mile-ometer /odometer
  • Mile-ometer /odometer
    Hi
    I have just bought my first Surf, but noticed the speedo works but the mileometer does not, is it most likely to be a cable that is faulty or are there other likely causes? is a toyota dealer the best place to source a new cable?
    Mike
    Welcome to the nut house!
    Don't know, but someone on here will.
    At a rough guess, with 10 minutes, Vince (Bushwhacker) will have posted the part number and a link to an exploded diagram.
    [starts stopwatch]
    Peter
    I am not a number. I am a FREE MAN!
      It might have been damaged when it was clocked mate! Only kidding.
      Welcome to the forum Mike. AFAIK the speedo cable drives the speedo, Odometer and the tripometer.
      It's only a hobby!
        Originally posted by Madmike999
        Hi
        Mike
        Only one cable m8.
        Has the speedo face been changed to MPH as part of the SVA? if so the mech doing the work cud a messed the clocks up.
        Or they could have been clocked and broken in the process.
        What vehicle do you have.
        I used to have a surf me!
          my surf has no cable , it has got 4 multi plugs along its top at the rear.its possible 1 has fallen off or isnt on properly.
            Oh! I better keep my nose out then
            I thought they were mechanical driven from a cable. Sorry
              Hi yes you're right it is electronic fault must be in the speedo head itself as it all works off the same impulse, trip and odeometer may just be jamed so strip down carefully and have a look
              If it aint broke dont fix it
