Hi,
Old chestnut I know but I have done the search and read some old posts with no joy.
My question is:-
I have no light when I press in the rear demist switch button with the ignition on. I have checked the bulb and also the connectors at the window, they are still on. Also there is no live at the window. Should the rear door be closed when I do this check and should the switch light up even if there is a feed problem at the window end?
Also can you tell me where to buy some new switch bulbs, they come away from the holder, so am I looking for bulbs with long connector tails?
Cheers.
My question is:-
Cheers.
